- Plesk 12.X for Linux
- Plesk Onyx for Linux
Nginx is stopped:
# service nginx status
nginx is stopped
nginx dead but pid file exists -
Cannot start Nginx:
# /etc/init.d/nginx start
Not starting nginx as it is disabled in config -
nginx service is disabled:
CentOS/RHEL:
# cat /etc/sysconfig/nginx
NGINX_ENABLED=no -
Debian/Ubuntu:
# cat /etc/default/nginx
NGINX_ENABLED=no
Nginx error log file at
/var/log/nginx/error.log
contains the following line:CONFIG_TEXT: [emerg] 2060#0: duplicate listen options for [2001:db8:f61:a1ff:0:0:0:80]:80 in /etc/nginx/plesk.conf.d/server.conf:29
Nginx is disabled for starting in its configuration
Enable nginx in it's configuration file:
CentOS/RHEL:
# vi /etc/sysconfig/nginx
Debian/Ubuntu:
# vi /etc/default/nginx
CONFIG_TEXT: NGINX_ENABLED=yes
in:
CentOS/RHEL:
NGINX_ENABLED=yes -
Debian/Ubuntu:
NGINX_ENABLED=yes
Reconfigure nginx and apache to listen to correct ports:
# plesk sbin nginxmng -d
# plesk sbin nginxmng -e
Disable nginx in Plesk to create correct configuration:
Note: LiteSpeed requires nginx to be disabled, as it cannot work with it.
