Incorrect IP address is added in Plesk with Point-to-Point interface
Created:
2016-11-16 13:16:54 UTC
Modified:
2017-08-16 14:11:43 UTC
Have more questions?
Submit a request
  • Plesk for Linux
  1. Point-to-Point interface is enabled on the server.
  2. When an IP address is refreshed in Plesk > Tools and Utilities > IP addresses , incorrect IP can be added (for example, 0.0.0.0.).
  3. The following error can appear in log:
    ERR (3)  [panel]: Apache config (13764416920.26609700) generation failed: Template_Exception: nginx: [emerg] bind() to 1.2.3.4:80 failed (99: Cannot assign requested address) nginx: configuration file /etc/nginx/nginx.conf test failed
    file: /opt/psa/admin/plib/Template/Writer/Webserver/Abstract.php
    line: 68
    code: 0
Or this error:
    New files of configuration for Apache web server were not built due to errors in configuration templates: Syntax error on line 156 of /usr/local/psa/admin/conf/generated/13937375940.28247400_server.include: The address or port is invalid
Plesk does not support Point-to-Point interfaces. This may break the configuration of IP addresses in Plesk. A request for implementation was created with ID #PPPM-774 that is considered to be implemented in future Plesk updates.
Delete the incorrect IP address from database:
  1. Create a backup of the psa database:
    mysqldump -uadmin -p`cat /etc/psa/.psa.shadow ` psa >psa.dump
  2. Delete the problem IP address:
    mysql> begin; delete from IP_Addresses where id=[empty IP address ID];
    Query OK, 0 rows affected (0.00 sec)
    Query OK, 1 row affected (0.00 sec)
    mysql> delete from ip_pool where ip_address_id=[empty IP address ID];
    mysql> commit;
