PHP handler other than FastCGI are not available for selection
Created:
2016-11-16 13:16:01 UTC
Modified:
2017-08-16 17:10:33 UTC
Have more questions?
Submit a request
  • Plesk Onyx for Linux
  • Plesk 11.x for Windows
  • Plesk 11.x for Linux
It is not possible to change domain PHP handler type under the Hosting Settings . Handler is set to "Run PHP as FastCGI Process Manager" and other PHP handlers are not available for selection.
The " Process PHP by nginx " option is enabled under the Web Server Settings for the domain in question.With this option enabled PHP files (.php) will be handled by nginx and PHP-FPM and so the FastCGI is used.
Go to Websites and Domains > Web Server Settings > disable " Process PHP by nginx "
