- Web Presence Builder for Linux
We need to disable the "
Publish
" button temporary so that the customer can't publish anything.
By default, the Parallels Presence Builder option is added to all feature lists in WHM ’s Feature Manager ( Packages > Feature Manager ). If you want to restrict access to Parallels Presence Builder, we recommend that you log in to WHM, review the existing feature lists, packages, and accounts, and make the corresponding adjustments.
To learn about how to set limits on the number of available Parallels Presence Builder sites for packages and user accounts, see the chapter "
Setting Limits on the Number of Sites Users Can Create
" (page 15):
Integrating Parallels Presence Builder 11 Standalone with cPanel & WHM 11.38.0
