Plesk upgrade failed: Configuration variable not found: APS_DB_DRIVER_LIBRARY
Created:
2016-11-16 13:15:02 UTC
Modified:
2017-08-16 17:34:16 UTC
Have more questions?
Submit a request
  • Plesk 10.x for Linux
  • Plesk 11.x for Linux
Plesk Control Panel shows the error after Plesk upgrade:
    PleskFatalException: Configuration variable not found: APS_DB_DRIVER_LIBRARY (Conf.php:61)
APS_DB_DRIVER_LIBRARY variable is absent in /etc/psa/psa.conf.
Resolution:
Check that APS_DB_DRIVER_LIBRARY variable exists in /etc/psa/psa.conf. If it is absent, please add parameter as below:
    [root@test]#cat /etc/psa/psa.conf | grep -i aps
# APS Controller
APS_DB_DRIVER_LIBRARY /usr/lib/libmysqlserver.so.2
