resolv.conf is being overwritten after container reboot
Created:
2016-11-16 13:14:29 UTC
Modified:
2017-08-08 13:37:46 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
resolv.conf is getting overwritten after container restart, all changes to the file are lost.
  1. Right after the start configuration file has nameserver and searchdomain set:
    [root@pvcfl ~]# vzctl start 100500
    Container is mounted
    Starting the Container ...
    Setting permissions 20002 dev 0x7d00
    Adding offline management to Container(1): 4643 8443 4649
    Adding IP addresses:
    Hostname of the Container set: container.tld
    File resolv.conf was modified
    [root@pvcfl ~]# vzctl exec 100500 cat /etc/resolv.conf
    nameserver 192.168.55.1
    search parallels.com
  2. We can rewrite the file, and changes will take effect:
    [root@pvcfl ~]# vzctl exec 100500 'echo "nameserver 10.20.30.40" > /etc/resolv.conf'
  3. However, after container restart all changes will be lost again:
    [root@pvcfl ~]# vzctl restart 100500
    Restart the Container
    Stopping the Container ...
    Stop the Container...
    Container was stopped
    Container is unmounted
    [root@pvcfl ~]#
Parallels Virtuozzo Containers controls /etc/resolv.conf configuration file if NAMESERVER or SEARCHDOMAIN values are specified in the container's configuration file:
[root@pvcfl ~]# grep -e NAMESERVER -e SEARCHDOMAIN /etc/vz/conf/100500.conf
NAMESERVER="192.168.55.1"
SEARCHDOMAIN="parallels.com"
Parallels Virtuozzo Containers won't overwrite /etc/resolv.conf if NAMESERVER or SEARCHDOMAIN settings are not set, thus if you want to give full control of the file to the container's user, you can unset these values:
[root@pvcfl ~]# vzctl unset 100500 --searchdomain --nameserver --save
Unset parameters for Container 100500
[root@pvcfl ~]#
Alternatively, you can just specify the correct nameserver or/and searchdomain with the help of vzctl tool:
[root@pvcfl ~]# vzctl set 100500 --nameserver 10.20.30.40 --searchdomain test.tld --save
Saved parameters for Container 100500
NAMESERVER="10.20.30.40"
SEARCHDOMAIN="test.tld"
[root@pvcfl ~]#
