Webservices are not working after upgrade of Plesk
Created:
2016-11-16 13:13:45 UTC
Modified:
2017-08-16 16:06:40 UTC
Have more questions?
Submit a request
  • Plesk 10.x for Linux
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
Web server is giving the error below and it cannot be configured after Plesk upgrade.
Unable to configure the web server: Execution failed. :
 ERR (3) [panel]: Apache config (13755595150.36596600) generation failed: Template_Exception: Syntax error on line 65 of /etc/httpd/conf/plesk.conf.d/vhosts/domain.tld.conf: FcgidIOTimeout must be greater than 0 file: /usr/local/psa/admin/plib/Template/Writer/Webserver/Abstract.php line: 68 code: 0 Syntax error on line 65 of /etc/httpd/conf/plesk.conf.d/vhosts/domain.tld.conf: Fcgid
According to official PHP documentation max_execution_time can get integer values.
But in case if it is set for example as -1 it states to PHP that script should be executed in less than 0 seconds.
Set correct value for max_execution_time PHP parameter, recommend value is 60 .
For unlimited value set max_execution_time PHP parameter to 0 .
