Unable to change Plesk administrator's password on CloudLinux: ch_owner failed
Created:
2016-11-16 13:12:20 UTC
Modified:
2017-08-17 07:45:48 UTC
Have more questions?
Submit a request
  • Plesk for Linux
Trying to change admin password through Plesk results in the error:
PLESK_ERROR: Error: Unable to change the administrator's password: ch_owner failed: file does not exist or is not executable: /usr/local/psa/admin/bin/ch_owner
  1. Permissions are not correct for /usr/local/psa/admin/bin/ch_owner .
  2. 'fs.enforce_symlinksifowner' is set to 1 by default that is not supported by Plesk. It effectively disables ability to run Plesk's wrapper.
    # grep sym /etc/sysctl.conf
    fs.enforce_symlinksifowner = 1
    fs.symlinkown_gid = 503
  1. Connect to the server using SSH.
  2. Check permissions for mentioned file, they should look as below:
    # ll /usr/local/psa/admin/bin/ch_owner
    lrwxrwxrwx 1 psaadm psaadm 15 Dec 26 15:22 /usr/local/psa/admin/bin/ch_owner -> ../sbin/wrapper
  3. Disable 'fs.enforce_symlinksifowner' (setting it to "0"):
    fs.enforce_symlinksifowner = 0
