Synchronization Failed (Common PHP settings management)
Created:
2016-11-16 13:12:05 UTC
Modified:
2017-08-16 16:11:23 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 11.x for Windows
  • Plesk 11.x for Linux
  • Plesk 12.0 for Windows
  • Plesk 12.5 for Windows
  1. Unable to sync the service Plan as a reseller.
  2. Syncing the subscription with its service plan failed because some of the services or resources defined in the plan cannot be actually provisioned with the subscription. Available value indicates the actual state of a resource or a service in the system. Clicking OK will initiate setting the subscription values according to the available values.
Also:
Reseller was created with this options unchecked: Common PHP settings management Service Plan created by reseller created with option Common PHP settings management
This is Plesk bug with ID PPPM-794 that  was fixed in micro-update #6 for Plesk 12: 12.0.18 MU#6
Install the latest Plesk micro-updates .
For Plesk 11.5, the following workaround is possible:
Sync subscription with service plan using command line utility:
    # /usr/local/psa/bin/subscription --sync-subscription example.com
Subscription example.com was synchronized with the associated service plans
