Using Micro-Updates in Plesk 8.x, 9.x, 10.x and Small Business Panel
Created:
2016-11-16 13:12:02 UTC
Modified:
2017-08-08 13:21:19 UTC
1
Have more questions?
Submit a request
  • Plesk
General information
Micro-update functionality is available in Plesk of versions 8.6 and later. It is implemented via autoinstaller utility, that can be used either in graphical mode or command line.
NOTE: During Micro-Update installation, the Panel service will be restarted.
In Plesk 9.5.5 and later, the functionality is available from the Panel under the "Updates" section.
Note: For installing micro-updates in EZ Templates, please see this Knowledge Base article: Installation of Micro-Updates if Plesk for Linux is installed inside containers by means of Virtuozzo template
Step-by-Step Guidance
There are two ways to install micro-updates for Plesk and Small Business Panel.
  1. Using command line interface:
    Linux:
    # $PRODUCT_ROOT_D/admin/sbin/autoinstaller
    Note: The $PRODUCT_ROOT_D variable in the command should be replaced with its value according to this Knowledge Base article: Plesk variables .
    For installing the latest Plesk micro-updates non-interactively, use the following command:
    # $PRODUCT_ROOT_D/admin/sbin/autoinstaller --select-product-id plesk --select-release-current --reinstall-patch --install-component panel
    For Small Business Panel:
    # $PRODUCT_ROOT_D/admin/sbin/autoinstaller --select-product-id ppsmbe --select-release-current --reinstall-patch --install-component base
    Windows:
    To install all micro-updates on Plesk or Plesk Small Business Panel 10 for Windows, use the following command:
    "%plesk_dir%\\admin\\bin\\ai.exe" --select-product-id panel --select-release-current --reinstall-patch --install-component panel
    Another product ID can be used instead of panel in the above command. Use the following command to see all available product IDs:
    %plesk_dir%\\admin\\bin\\ai.exe --show-all-releases
    --- prod_id release_id (description) (branch) ---
    panel PANEL_10_4_4_WIN (Plesk 10.4.4) (currently installed)
    panel PANEL_10_3_1_WIN (Plesk 10.3.1) (stable)
    ppsmbe PPSMBE_10_2_0_WIN (Small Business Panel 10.2.0) (stable)
    plesk-updates PLESK_9_5_5_WIN (Plesk 9.5.5 updates) (stable)
  2. Using graphical interface:
    a. Plesk 9.5: Home -> Updates > Select the Plesk version that has the updates -> Click Install .
    b. Plesk 10.0.1: Server Management > Tools & Utilities > Updates > Update Components > Click Continue .
    c. Small Business Panel: Settings > Updates > Click Continue .
Checking whether micro-updates are installed on the system
Since Plesk 10.4, installed micro-updates can be checked under the "Updates" section of Plesk graphical interface.
For earlier Plesk versions:
Linux:
Check the /root/.autoinstaller/microupdates.xml file:
    # cat /root/.autoinstaller/microupdates.xml
It should contain the latest patch version:
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<patches>
<product id="plesk" version="10.0.1">
<patch version="1" timestamp=""/>
</product>
</patches>
This text means that micro-update #1 is installed on Plesk. For example, if < patch version="6" timestamp="" /> is shown, it means that micro-update #6 is installed.
Windows:
Check the C:\\ParallelsInstaller\\microupdates.xml file.
Alternatively, registry can be checked:
For 64-bit systems:
    C:\\Users\\Administrator>reg query "HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\PLESK\\PSA Config\\Config" |findstr InstalledPatches
InstalledPatches REG_SZ panel-10.4.4-39
For 32-bit systems:
    C:\\Users\\Administrator>reg query "HKEY_LOCAL_MACHINE\\SOFTWARE\\PLESK\\PSA Config\\Config" | findstr InstalledPatches
Additional information
Using Micro-Updates in Plesk 11.x and 12.x
