Integration is not working with paper_lantern theme
Created:
2016-11-16 13:11:36 UTC
Modified:
2017-08-16 16:13:25 UTC
Have more questions?
Submit a request
  • Web Presence Builder for Linux
  • Plesk 11.x for Linux
Cannot integrate Web Presence Builder and Cpanel with paper_lantern theme.
Integration with paper_lantern theme is not supported.
According to release notes , only x3 theme is supported:
The cPanel & WHM plugin requires that the following components be installed on the server, where sites will be hosted:
cPanel & WHM 11.38.0 with the x3 theme. The plugin cannot work with themes other than x3.
