How to fix InnoDB corruption cases for the MySQL databases on Plesk for Linux?
7 comments
    Pedro Telmo
    Hi:
    What information must content the file /root/db_list.txt ?
    Regards
    Artyom Baranov
    @Pedro Telmo,
    Hi! After executing the following command:
    # mysql -Ns -uadmin -p`cat /etc/psa/.psa.shadow` -e"SHOW DATABASES" > db_list.txt
    it should contain the names of all databases that are stored on MySQL server.
    -1
    Pedro Telmo (Edited )
    Yes Artyom.
    Alisa Kasyanova add this line after my comment :)
    Thanks
    Mskumar Blaze
    2018-02-21T14:59:14.908905Z 12 [ERROR] Plugin group_replication reported: 'Fatal error during the Recovery process of Group Replication. The server will leave the group.'
    Mskumar Blaze
    I have some doubt I have configured innodb cluster (3 cluster) after I created I’ll be going to stop group replication in (cluster2) then I had to rejoin cluster2 after I rejoined cluster2 status as recovering after some times it’s going to show missing. My cluster1-(primary) log status Warning] Plugin group_replication reported: 'Members removed from the group: 608781bce352:3306'
    2018-02-21T14:59:16.115814Z 0 [Note] Plugin group_replication reported: 'Group membership changed to d5e07af19ef5:3306, 812606eb6abb:3306 on view 15191888786747824:12.'
    2018-02-21T15:00:13.434470Z 148 [Note] Aborted connection 148 to db: 'unconnected' user: 'mysql_innodb_cluster_r1721619408' host: 'cluster2.willing' (failed on flush_net())
    2018-02-21T15:16:48.046190Z 141 [Note] Aborted connection 141 to db: 'unconnected' user: 'root' host: 'd5e07af19ef5' (Got an error reading communication packets)
    My cluster2 log status Warning] Plugin group_replication reported: 'Members removed from the group: 608781bce352:3306'
    2018-02-21T15:16:48.046190Z 141 [Note] Aborted connection 141 to db: 'unconnected' user: 'root' host: 'd5e07af19ef5' (Got an error reading communication packets). I got confused kindly help me please...
    Ivan Postnikov
    @Mskumar Blaze
    Hello!
    I would suggest contacting MySQL Technical Support regarding this issue as they are experts in their product.
    Iman GM
    Thanks Leonid!
    This article was a lifesaver. Worked great and the problem was fixed.
