- Plesk Onyx for Linux
The following error is shown in Plesk:
PLESK_INFO: ERROR: PleskMainDBException
MySQL query failed: Incorrect information in file: './psa/misc.frm'OR
PLESK_INFO: ERROR: PleskDBException: Unable to connect to database: mysql_connect(): No such file or directory /var/run/mysqld/mysqld.sock (Error code: 2002). Please check that database server is started and accessible. (Abstract.php:69)
ORPLESK_INFO: ERROR: Zend_Db_Adapter_Exception: SQLSTATE[HY000] [2002] No such file or directory
- Domain overview page on Domains > example.com is not accessible:
CONFIG_TEXT: 500 Server Error
Type SB_Facade_Exception_Generic
Message
File
generic.php Line 33 -
Plesk upgrade fails with the following error:
PLESK_INFO: DATABASE ERROR!!!
Database psa database found, but version undefined -
MySQL service does not start:
# service mysqld start
Timeout error occurred trying to start MySQL Daemon.
Starting MySQL: [FAILED] -
mysqldump
andmysqlcheck
utilities fail with an error message claiming a table does not exist (use the MySQL administrator account to check):# mysqlcheck -uadmin -p****** db_example
db_example.BackupTasks
error : Can't find file: 'BackupTasks.MYD' (errno: 2) -
A table cannot be properly queried with the
mysql> SELECT
statement:MYSQL_LIN: select * from db_example.misc;
ERROR 1033 (HY000): Incorrect information in file: './db_example/misc.frm' -
The table cannot be repaired because the InnoDB engine does not support repair queries.
# mysql> repair table misc;
| Table | Op | Msg_type | Msg_text |
| psa.APSApplicationItems | repair | note |The storage engine for the table doesn't support repair|
The following information can be found in the MySQL log file:
CONFIG_TEXT: 150704 19:09:27 InnoDB: Waiting for the background threads to start
150704 19:09:28 InnoDB: Error: tablespace size stored in header is 3712 pages, but
150704 19:09:28 InnoDB: the sum of data file sizes is only 3072 pages
150704 19:09:28 InnoDB: Cannot start InnoDB. The tail of the system tablespace is
150704 19:09:28 InnoDB: missing. Have you edited innodb_data_file_path in my.cnf in an
150704 19:09:28 InnoDB: inappropriate way, removing ibdata files from there?
150704 19:09:28 InnoDB: You can set innodb_force_recovery=1 in my.cnf to force
150704 19:09:28 InnoDB: a startup if you are trying to recover a badly corrupt database.Or
CONFIG_TEXT: InnoDB: Assertion failure in thread 3876 in file ha_innodb.cc line 17352
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/5.6/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.Or
CONFIG_TEXT: InnoDB: Assertion failure in thread 140154354255616 in file trx0purge.c line 848
OR
InnoDB: Failing assertion: purge_sys->purge_trx_no <= purge_sys->rseg->last_trx_no
InnoDB: We intentionally generate a memory trap.CONFIG_TEXT: InnoDB: Your database may be corrupt or you may have copied the InnoDB tablespace but not the InnoDB log files. Please refer to http://dev.mysql.com/doc/refman/5.7/en/forcing-innodb-recovery.html for information about forcing recovery
ORCONFIG_TEXT: [ERROR] InnoDB: Attempted to open a previously opened tablespace. Previous tablespace database/table uses space ID: 882 at filepath
InnoDB corruption.
Most InnoDB corruptions are hardware-related. Corrupted page writes can be caused by power failures or bad memory. The issue also can be caused by using network attached storage (NAS) and allocating InnoDB databases on it.
Note: Since the MySQL service's control, logs and configuration file's location is different on the different operating systems, this article provides general command examples only. Check the following article for additional information regarding MySQL on different operating systems
[Linux] Local MySQL server for all databases
For additional information check your operating system and MySQL documentation.
Note: for Windows, see the following article: How to fix InnoDB corruption cases for the MySQL databases on Plesk for Windows?
There are several ways to recover a failed MySQL database:
Stop the affected MySQL service. See the note above regarding service's control.
Back up all the MySQL data storage files. By default, they are located in
/var/lib/mysql/
For example:
# mkdir /root/mysql_backup
# cp -a /var/lib/mysql/* /root/mysql_backup/ -
Set the
value under the[mysqld]
section in the MySQL configuration file. This option will allow you to start MySQL service and create all databases dump.For example:
# vi /etc/my.cnf
[mysqld]
innodb_force_recovery = 1Warning: Only set
to a value greater than 0 in an emergency situation, so that you can start InnoDB and dump your tables. Values of 4 or greater can permanently corrupt data files. Therefore, increase this value incrementally, as necessary. Please see more details in the official MySQL Documentation. -
Start the MySQL service.
- If the service fails with an error like:
CONFIG_TEXT: InnoDB: Waiting for the background threads to start
Add directive
innodb_purge_threads
according to the following article: Unable to start MySQL service: InnoDB: Waiting for the background threads to start
Try to dump all databases:
# MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -Ns -uadmin psa -Ne"show databases"|grep -v information_schema | grep -v performance_schema > /root/db_list.txt
# mkdir /root/db_backup/
# cat /root/db_list.txt | while read i; do MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysqldump -uadmin "$i" --routines --databases > /root/db_backup/"$i".sql; echo $i; sleep 5; done- If the dump fails with an error like:
CONFIG_TEXT: Incorrect information in file: './psa/APSApplicationItems.frm' when using LOCK TABLES"`
then increase
value, restart MySQL service, and try to dump the databases again. It is better to dump databases one by one, separately. In that case, there is no need to go through restore of all databases once again if restore failed for some reason.
If unable to dump the databases, then try using method II (Copy table content) or III (Restore from the backup) which are described below. -
Remove all the MySQL data storage files except the
mysql
folder. For example:# rm -rf `ls -d /var/lib/mysql/* | grep -v "/var/lib/mysql/mysql"`
Remove the
option from the MySQL configuration file. -
Restart the MySQL service:
# service mysqld restart
Check the MySQL log file for any errors.
Restore databases from the dumps made on the 5th step. For example:
# for db in `cat /root/db_list.txt`; do echo -e "Importing $db..."; MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -uadmin < /root/db_backup/$db.sql; done
Repeat steps #1-4 from the method I to back up all the MySQL data storage files and enable InnoDB recovery mode.
Try to make a copy of a table:
MYSQL_LIN: CREATE TABLE <new_table> LIKE <crashed_table>;
MYSQL_LIN: INSERT INTO <new_table> SELECT * FROM <crashed_table>; -
If the copy was created successfully, then replace corrupted table with newly created:
MYSQL_LIN: RENAME TABLE <crashed_table> TO <old_table>;
MYSQL_LIN: RENAME TABLE <new_table> TO <crashed_table>;
MYSQL_LIN: DROP TABLE <old_table>;Note: Depending on the MySQL version used, it might be necessary to set lower
value or remove it from the MySQL configuration file and restart MySQL service to successfully perform theDROP
andRENAME
operations. Please see more details in the official MySQL Documentation.
If the instructions above did not help, the only remaining method is to restore the databases from backups. Do not forget to remove the innodb_force_recovery
option from the MySQL configuration file before restore.
To restore Plesk-related databases (psa, apsc, horde) see How to backup/restore a Plesk database dump article. For example:
# ls -tl /var/lib/psa/dumps
-rw------- 1 root root 141960 Aug 8 01:03 mysql.daily.dump.0.gz
-rw------- 1 root root 141925 Aug 7 01:03 mysql.daily.dump.1.gz
# zcat /var/lib/psa/dumps/mysql.daily.dump.0.gz | MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -u admin psa -
To restore customer's databases from Plesk backup see the Restoring Data from Backup Archives section in the Administrator's Guide.
Note: If timeouts are encountered when restoring databases, set the
wait_timeout
value in the MySQL configuration file and restart the MySQL service. For example:# vi /etc/my.cnf
[mysqld]
wait_timeout = 1800
6 comments
Hi:
What information must content the file /root/db_list.txt ?
Regards
@Pedro Telmo,
Hi! After executing the following command:
it should contain the names of all databases that are stored on MySQL server.
Yes Artyom.
Alisa Kasyanova add this line after my comment :)
Thanks
2018-02-21T14:59:14.908905Z 12 [ERROR] Plugin group_replication reported: 'Fatal error during the Recovery process of Group Replication. The server will leave the group.'
I have some doubt I have configured innodb cluster (3 cluster) after I created I’ll be going to stop group replication in (cluster2) then I had to rejoin cluster2 after I rejoined cluster2 status as recovering after some times it’s going to show missing. My cluster1-(primary) log status Warning] Plugin group_replication reported: 'Members removed from the group: 608781bce352:3306'
2018-02-21T14:59:16.115814Z 0 [Note] Plugin group_replication reported: 'Group membership changed to d5e07af19ef5:3306, 812606eb6abb:3306 on view 15191888786747824:12.'
2018-02-21T15:00:13.434470Z 148 [Note] Aborted connection 148 to db: 'unconnected' user: 'mysql_innodb_cluster_r1721619408' host: 'cluster2.willing' (failed on flush_net())
2018-02-21T15:16:48.046190Z 141 [Note] Aborted connection 141 to db: 'unconnected' user: 'root' host: 'd5e07af19ef5' (Got an error reading communication packets)
My cluster2 log status Warning] Plugin group_replication reported: 'Members removed from the group: 608781bce352:3306'
2018-02-21T15:16:48.046190Z 141 [Note] Aborted connection 141 to db: 'unconnected' user: 'root' host: 'd5e07af19ef5' (Got an error reading communication packets). I got confused kindly help me please...
@Mskumar Blaze
Hello!
I would suggest contacting MySQL Technical Support regarding this issue as they are experts in their product.
