If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
How to fix InnoDB corruption cases for the MySQL databases on Plesk for Linux?
11 comments
    Pedro Telmo
    Hi:
    What information must content the file /root/db_list.txt ?
    Regards
    Artyom Baranov
    @Pedro Telmo,
    Hi! After executing the following command:
    # mysql -Ns -uadmin -p`cat /etc/psa/.psa.shadow` -e"SHOW DATABASES" > db_list.txt
    it should contain the names of all databases that are stored on MySQL server.
    -1
    Pedro Telmo (Edited )
    Yes Artyom.
    Alisa Kasyanova add this line after my comment :)
    Thanks
    Mskumar Blaze
    2018-02-21T14:59:14.908905Z 12 [ERROR] Plugin group_replication reported: 'Fatal error during the Recovery process of Group Replication. The server will leave the group.'
    Mskumar Blaze
    I have some doubt I have configured innodb cluster (3 cluster) after I created I’ll be going to stop group replication in (cluster2) then I had to rejoin cluster2 after I rejoined cluster2 status as recovering after some times it’s going to show missing. My cluster1-(primary) log status Warning] Plugin group_replication reported: 'Members removed from the group: 608781bce352:3306'
    2018-02-21T14:59:16.115814Z 0 [Note] Plugin group_replication reported: 'Group membership changed to d5e07af19ef5:3306, 812606eb6abb:3306 on view 15191888786747824:12.'
    2018-02-21T15:00:13.434470Z 148 [Note] Aborted connection 148 to db: 'unconnected' user: 'mysql_innodb_cluster_r1721619408' host: 'cluster2.willing' (failed on flush_net())
    2018-02-21T15:16:48.046190Z 141 [Note] Aborted connection 141 to db: 'unconnected' user: 'root' host: 'd5e07af19ef5' (Got an error reading communication packets)
    My cluster2 log status Warning] Plugin group_replication reported: 'Members removed from the group: 608781bce352:3306'
    2018-02-21T15:16:48.046190Z 141 [Note] Aborted connection 141 to db: 'unconnected' user: 'root' host: 'd5e07af19ef5' (Got an error reading communication packets). I got confused kindly help me please...
    Ivan Postnikov
    @Mskumar Blaze
    Hello!
    I would suggest contacting MySQL Technical Support regarding this issue as they are experts in their product.
    Iman GM
    Thanks Leonid!
    This article was a lifesaver. Worked great and the problem was fixed.
    1
    Carlos Domingo Arias González
    Me funcionó correctamente, gracias !!!
    1
    Bendert Feenstra
    Absolute lifesaver!! Had a VPS installation with multiple hosted sites that could not start the mysql service all of a sudden (or to be more precise MariaDB). Was hesitant to try this; not that I didn't trust it, just had hopes that restarting would resolve this. Very glad that after 3 hours of trying other things I followed the Force InnoDB recovery description above. All hosted sites are now up and running again as if nothing happened.
    Del C
    I would recommend changing the dump line to:
    cat /root/db_list.txt | while read i; do MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysqldump -uadmin "$i" --routines --hex-blob --databases > /root/db_backup/"$i".sql; echo $i; sleep 5; done
    Adding --hex-blob will dump binary columns using hexadecimal notation. I you don't, then depending on your db contents, on import you will get an error similar to: Mysql ERROR at line 1153: Unknown command '\'
    Taras Ermoshin
    Hi @Del C!
    Thanks for sharing, this information may be useful to other Pleskians!
