Plesk utilities are not working with VZCTL EXEC
Created:
2016-11-16 13:08:50 UTC
Modified:
2017-08-08 13:36:22 UTC
Have more questions?
Submit a request
  • Plesk for Windows
I need to make changes to all containers running Parallels Plesk Panel massively from node. What is the proper way to do this?
Plesk utilities in containers can be executed from a hardware node in several ways.
  1. By using vzctl exec and specifying that cmd program inside the container should be used.
    Example:
    > vzctl exec 103 cmd /c %plesk_bin%\\subscription.exe -i domain.com
    Or
    > vzctl exec 103 cmd /c C:\\Parallels\\Plesk\\admin\\bin\\subscription.exe -i domain.com
  2. By creating a file with .cmd extension on host containing necessary commands. Then you can apply it to all containers at once by:
    > for /f %i in ('vzlist -Ho veid') do vzctl enter %i < mycommand.cmd
(do not forget to end .cmd file with "exit", otherwise "vzctl enter" would not quit)
