How to change IP address for domains/clients/resellers in Plesk for Linux
5 comments
    John Bertin
    I get the following error;
    sh: 2: Syntax error: newline unexpected
    1
    Ivan Postnikov
    Hello @Farid, thank you for sharing your user experience.
    The recommended way is to, at first, change the interface primary IP.
    Please, check this article for the reference.
    Farid Bestenli
    Update: I managed to delete the ip address using the commands:
    # plesk db
    # delete from IP_Addresses where ip_address='192.168.x.x';
    Alexandr Bashurov
    @John Bertin
    Please, try running this command instead:
    for i in $(plesk bin subscription -l); do plesk bin subscription -u "$i" -ip <ip_address>; done
    Farid Bestenli
    I already have the new ip address registered in plesk but i can't delete it. So what's the solution?
    Error: Cannot remove the IP address 192.168.x.x because it is used by an active session. Cannot remove the IP address 192.168.x.x because it is the primary IP address of a network interface.
