How to change the IP address for domains/clients/resellers in Plesk for Linux?
8 comments
    Farid Bestenli
    I already have the new ip address registered in plesk but i can't delete it. So what's the solution?
    Error: Cannot remove the IP address 192.168.x.x because it is used by an active session. Cannot remove the IP address 192.168.x.x because it is the primary IP address of a network interface.
    Farid Bestenli
    Update: I managed to delete the ip address using the commands:
    # plesk db
    # delete from IP_Addresses where ip_address='192.168.x.x';
    Ivan Postnikov
    Hello @Farid, thank you for sharing your user experience.
    The recommended way is to, at first, change the interface primary IP.
    Please, check this article for the reference.
    John Bertin
    I get the following error;
    sh: 2: Syntax error: newline unexpected
    1
    Alexandr Bashurov
    @John Bertin
    Please, try running this command instead:
    for i in $(plesk bin subscription -l); do plesk bin subscription -u "$i" -ip <ip_address>; done
    JP Kelly
    When I try this it hangs after updating one subscription. If I 'command C' out of the loop and try again it does the next subscription but this is very tedious. Any ideas?
    Maxim Krasikov
    Hi @JP Kelly,
    Please make sure that the command was fully copied:
    for i in $(plesk bin subscription -l); do plesk bin subscription -u $i -ip <ip_address>; done
    If it is not helpful, try executing an alternative command:
    MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -Ns -uadmin -D psa -e 'select name from domains' | awk '{print "/usr/local/psa/bin/domain --update " $1 " -ip <ip_address> "}' | sh
    Alternatively, submit a ticket to Plesk support in order to check if there is a misconfiguration from the server side:
    Ehud Ziegelman
    This article does NOT work well
    Please test it and fix the steps to be taken.
