Plesk for Windows
Plesk for Linux
kb: how-to
ABT: Group A
- Plesk for Windows
How to enable/disable web statistics for a domain in Plesk?
Enabling/disabling web statistics via Plesk
Go to Domains > example.com > Hosting Settings.
Set Web statistics to according to your needs. None means disabled.
Enabling/disabling web statistics via a command-line interface
Connect to the Plesk server via SSH (Linux) / RDP (Windows Server).
Execute the following command via the command line:
CONFIG_TEXT: plesk bin domain --update example.com -webstat <option>
where available options are:
none
awstats
webalizer
Additional Information
There are two web-statistics tools that come along with Plesk and can be installed via Plesk Installer:
- AWStats
- Webalizer
