If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
mod_perl, mod_python, mod_php Apache modules are not installed by default in Plesk
4 comments
    Fouad Ahmed Fouad
    File security with mod_php could be resolved by using other modules like mod_ruid2 which will enable every web site to work under its user owner such as FastCGI.
    Mod_php still needed in some scenarios such as when using a shared folder among web sites, some companies use Plesk to manage their own web sites and not as a shared hosting platform, so they have shared folders among web sites to store shared big images folders among web sites, I have a like scenario which a folder of 150G is shared among about 8 web sites.
    Ivan Postnikov (Edited )
    Hello @Fouad,
    As it is stated in this article, Apache doesn’t allow multiple versions of PHP using mod_phpmod_php can be enabled only for OS PHP.
    To enable mod_php for OS PHP check Apache handler is not available in Plesk article.
    Please, note that enabling the mod_php Apache handler is not safe as it is outdated and insecure.
    Check this article for instructions to add PHP modules.
    Fouad Ahmed Fouad
    Hello Ivan,
          Some companies have to use mod_php on its own Plesk servers because they share code among their web sites, please note that not ALL companies are using Plesk for web hosting!
    For now I try on Obsedian to enable mod_php and when I tried to visit the links you recommended it says,
    You're not authorized to access this page
    This company for example share a folder which its size is about 500G among web sites hosted on their own Plesk, I need mod_php so I can use Apache user to be able to read and write to this folder from all sites hosted at Plesk, can you recommend another solution?
    I know i could greate a new group and add all web site system users to it so they share folders but I see to use mod_php is easier as this server has that config and it works well. please advise?
    Yulia Plokhotnikova
    Hi @Fouad Ahmed Fouad,
    Indeed, the article was hidden as enabling mod_php can lead to serious security issues. But I will send instructions for you here so that you can enable it on your side:
    1. In Plesk, go to Tools & Settings > Apache Web Server:
      1.1. Change the MPM mode to Prefork.
      1.2. Click Apply.
      1.3. Enable the 'php5' module.
      1.4. Click OK.
      • Additionally on Debian/Ubuntu-based distributions, connect to a Plesk server via SSH and apply the following commands additionally:
        touch /var/lib/apache2/module/disabled_by_admin/mpm_event
        # touch /var/lib/apache2/module/enabled_by_admin/mpm_prefork
        # touch /var/lib/apache2/module/enabled_by_admin/php5
    2. Then, go to Tools & Settings > PHP Settings. and enable the Apache mod_php handler.
    3. To set the Apache mod_php handler for a domain, go to Domains > example.com > PHP Settings: Select PHP version by OS vendor and run PHP as mod_php.
