How to monitor PHP-FPM instances
8 comments
    Peter Debik
    I tried to solve https://talk.plesk.com/threads/file-not-found-on-php-fpm-status-page.342581/ , rebuilt the configuration on a test system here and came to the same conclusion as the other user: It does not work, only displays "File not found". I tried several things, e.g. replacing fastcgi_param line with "fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;" as described in threads throughout the Internet, but only got the "File not found" result. Onyx 17.5 on CentOS 7.3 64-Bit. What's the correct solution?
    Andrey Ivanov
    Hello Peter,
    The article has been modified accordingly. Please feel free to check it.
    S. Jay
    Same here... only File not Found.
    Ubuntu 16.04 with Plesk 17.5.3
    Peter Debik
    I confirm that this solution works. Thank you.
    Lev Iurev
    Hi Sebastian, please prvide me with more details.
    Sharul Hafiz
    Hi. How to monitor PHP-FPM instances with apache?
    1
    Yulia Plokhotnikova
    @Sharul Hafiz
    We will need to check it additionally on our side. I will create a ticket for you in order to send an update to you directly. Then we will add new information to this article.
    Yulia Plokhotnikova
    @Sharul Hafiz
    I carefully checked how to convert nginx directives to ones for apache (for .htacess), but did not find a solution that would work in this case.
    So currently such functionality is not supported in Plesk. You may want to suggest new functionality in Plesk on Plesk User Voice portal:
    https://plesk.uservoice.com/forums/184549-feature-suggestions
