- Plesk for Windows
Domain's statistics has been changed. How to manually recalculate statistics for one domain to reflect the changes in Plesk?
Note: This guide is intended for Plesk administrators with an SSH/RDP access to a Plesk server. If you are a domain owner, please contact your service provider for assistance.
Click on a section to expand
Connect to a Plesk server via SSH.
Use the 'statistics' utility to calculate web page access statistics, traffic usage statistics and disk space usage statistics:
# plesk sbin statistics --calculate-one --domain-name=example.com
Connect to a Plesk server RDP .
C:\> plesk sbin statistics --calculate-one --domain-name=example.com
C:\> "%plesk_bin%"\web_statistics_executor.exe --calculate-domain --domain-name=example.com --webspace-name=example.com
If the command does not result in the statistics update, execute the below command:
C:\> "%plesk_bin%"\statistics.exe --generate-domain-webstat --domain-name=example.com
6 comments
Hi, if I recalculate the statistics, my customer are suspend after a night. Is there a job scheduled? Which job? Can I test it and, in test phase, suspend immediately a test-customer?
@Gilberto
Statistics are calculated during Daily Tasks' "ExecuteStatistics" part. You may run it separately like this (if you use Windows) or this (if you use Linux).
Customer gets suspended most likely because of exceeded limits (please check this article).
Would running "/usr/local/psa/admin/sbin/statistics --calculate-one --domain-name=example.com" also rotate the logs, for that domain, if the logs were above the size threshold specified in the log rotation settings for the domain? Can I add a scheduled task for command to run for a domain whose logs grow very large before the daily log rotation occurs?
@Bob B
Yes, this command also runs the log rotation, as well as the statistics recalculation.
if i had email notification enabled for abo quota exceeds, will that be triggered too with that command?
Hi Johannes Fuchs,
It shoudn't as in my opinion the notification is sent by the daily task, not by the utility that calculates the statistics.
