How to add PTR record for a domain in Plesk?
Created:
2016-11-16 13:04:52 UTC
Modified:
2017-08-14 16:01:44 UTC
4
Have more questions?
Submit a request
  • Plesk
How to add a PTR record in Plesk?
If you use DNS server installed with Plesk, to add a new resource record to the zone:
  1. Go to the Domains > example.com > DNS Settings
  2. Click Add Record .
  3. Select record type as PTR , and specify the appropriate data.
  4. Click OK, and then click Update.
Note: Plesk UI supports creating PTR records with the following subnet masks: 8, 16, 24.
General documentation about DNS management in Plesk can be found in Plesk Administrators Guide .
For more details on PTR records and its format check the following link http://help.dnsmadeeasy.com/managed-dns/dns-record-types/ptr-record/
