How to upload a Plesk license using web interface?
Created:
2016-11-16 13:04:24 UTC
Modified:
2017-08-08 13:13:25 UTC
3
Have more questions?
Submit a request
  • Plesk
Instructions to install license key on different versions of Plesk:
Plesk 12, 12.5 and Plesk Onyx
To install a license key using an activation code:
  1. Go to Tools & Settings > License Management > Plesk License Key > Install Key .
  2. Enter your Plesk activation code and click "OK".
To install a license key using a license key file:
  1. Go to Tools & Settings > License Management > Plesk License Key > Install Key ..
  2. Choose Upload a license key file .
  3. Specify the path to the key file and click OK .
Plesk 11.x:
  1. Go to Tools & Settings > License Management > Parallels Panel License Key > Install Key .
Plesk 10.x:
  1. On your Home page, click Tools & Utilities > License Management .
  2. Click Upload Key .
  3. Specify the path to the license key file location: enter the path into the input box provided, or click Browse to browse for the desired location.
  4. Select the Replace the currently installed license key with the selected one check box.
  5. Click OK to submit.
Plesk 9.x:
  1. Under Help & Support Section, click on License Management > Upload Key
  2. Enter the path to the key file that you saved on your local machine or click ‘Browse’ to locate it.
  3. Select the Replace the currently installed license key with the selected one check box. If this check box is not selected, the new license key will not be installed and installation will be aborted.
Plesk 8.x:
  1. Open the License Management screen in Plesk: Server > License Management > Upload Key
  2. Enter the path to the key file that you saved on your local machine or click Browse to locate it.
For details about installing a license through the command line, refer to the following article:
  • 213382849 How to install/update Plesk license from command line?
