- Plesk 12.0 for Windows
- Plesk 12.5 for Windows
In Plesk, the following CAS trust levels are available: Minimal, Low, Medium, High, Full.
How to set the required one?
Apply one of the following solutions:
- Log into Plesk.
- Go to Tools & Settings > ASP.NET Settings.
- Select from the drop-down menu CAS trust level the required level.
- Press the OK button to apply the changes.
Note: customers can change this value for each domain in case the Allow to override the CAS trust level for websites option is switched on by the administrator in Tools & Settings > ASP.NET Settings.
- Log into the server via RDP.
- Execute the command below:
C:\> "%plesk_bin%"\\aspnetcfg.exe --machine --trust-level=Medium
Note: in the current example CAS trust level was set to Medium
The administrator can change it for each domain through the command-line:
C:\>"%plesk_bin%"\\aspnetcfg.exe --machine --trust-level-allow-override=true
C:\>"%plesk_bin%"\\aspnetcfg.exe --domain-name=domain.tld --trust-level=Minimal
