Parallels Plesk Panel stops working after Zend Optimizer installation.
Created:
2016-11-16 13:03:43 UTC
Modified:
2017-08-08 13:35:04 UTC
Have more questions?
Submit a request
  • Plesk for Windows
  • Plesk 12.5 for Linux
Parallels Plesk Panel stops working after the installation of Zend Optimizer.
The reason for the problem is that Zend sets a path to the php.ini file in the registry:
HKEY_LOCAL_MACHINE\\SOFTWARE\\PHP\\IniFilePath=C:\\WINDOWS
Therefore, all .php scripts on the server start using this setting and use the C:\\WINDOWS\\php.ini file for PHP configuration.
To fix this problem , the following key needs to be removed:
  • On x86 servers - HKEY_LOCAL_MACHINE\\SOFTWARE\\php\\IniFilePath
  • On x64 servers - HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\PHP\\IniFilePath
Then, all .php scripts will use the correct .ini files.
Additional Information
Please alse see article #3041 .
