- Plesk 12.0 for Linux
Can not start MariaDB, the following error appears in status:
~]# systemctl status mariadb.service -l
mariadb.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled)
Active: failed (Result: exit-code) since Sat 2015-05-30 12:37:44 CEST; 24min ago
Process: 2674 ExecStartPre=/usr/libexec/mariadb-prepare-db-dir %n (code=exited, status=203/EXEC)
May 30 10:38:42 domain.tld mariadb-prepare-db-dir[3468]: Failed at step EXEC spawning /usr/libexec/mariadb-prepare-db-dir: Permission denied
The following errors can be found in
/var/log/mariadb/mariadb.log
150530 11:05:37 [ERROR] mysqld: Can't create/write to file '/tmp/ibH5045r' (Errcode: 13)
150530 11:05:37 InnoDB: Error: unable to create temporary file; errno: 13
150530 11:05:37 [ERROR] mysqld: Can't create/write to file '/var/lib/mysql/aria_log_control' (Errcode: 13)
150530 11:05:37 [ERROR] mysqld: Got error 'Can't create file' when trying to use aria control file '/var/lib/mysql/aria_log_control'
However,
have a proper permissions.
~]# stat /usr/libexec/mariadb-prepare-db-dir
File: '/usr/libexec/mariadb-prepare-db-dir'
Size: 3015 Blocks: 8 IO Block: 4096 regular file
Device: 3820b611h/941667857d Inode: 410510 Links: 1
Access: (0755/-rwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Permissions on
is set as follows:
~]# ls -la /
total 120
drwxrwx--- 19 root root 4096 May 30 11:59 .
drwxrwx--- 19 root root 4096 May 30 11:59 ..
Invalid permissions on
, as a result only
root
user can execute.
Set permission on
~]# chmod a+x /
