Let's Encrypt auto renew is not working for domains or Plesk with renamed certificates
14 comments
    Mark Wijsman
    Any clue on when this will be fixed? As for the past i've told all my customers to ignore the emails from let's encrypt because it's just a reminder that the certificate will be renewed, I'm getting a lot of annoyed emails about SSL errors every day.
    Anzhelika Khapaknysh
    @Mark Wijsman,
    There is no ETA at the moment.
    I do recommend applying the workaround until the bug is fixed.
    Betafer
    Hello, any news ?
    Alexey Lapshin
    Hello @Betafer
    The fix is planned to be implemented in the next major release of extension, however there is no exact ETA for it currently.
    Ariel Lipschutz
    Any update?
    your workaround doesn't work if you have a lot of domains!
    The email has no information about what domain is expired/having problems...
    At least, you could add what domain is not renovating
    Pierre Lauret
    version 2.9.0 seems to have corrected this bug ?
    [-] Auto-renew of SSL/TLS certificates no longer fails after a secured domain or subdomain was renamed. (EXTLETSENC-768)
    Francisco Garcia
    Hi Ariel Lipschutz,
    It is still planned for the next major release of the extension, but no ETA yet :(
    Hi Pierre Lauret,
    No, it's not yet fixed as the bug you're pointing out is another one.
    Kevin Mamaqi
    Any update on this issue? It is really annoying.
    Ivan Postnikov
    Hello Kevin Mamaqi
    The recent reply of my colleague is still actual: the exact ETA is to be available later.
    As soon as there'll be any news, the article will be updated.
    David / Curtis
    I am now getting this notice on some sites every 48 hours on v.2.9.0-611. I can't run a business this way.
    At this point I need to know how to downgrade both Plesk and Let's Encrypt to something that works.
    Ivan Postnikov
    Hello David / Curtis
    The issue from this article happens with renamed certificates only.
    Most probably you have another root cause and investigation of your issue is required. Plesk downgrade is an impossible operation.
    Could you submit a request to Plesk support for additional investigation?
    Henry C. Lavau
    The strange thing is that
    1. Even after a successful manual renewal, Plesk will continue to try to renew a valid certificate up to three months in advance
    2. But it will fail, sending an email stating that the certificate has expired
    3. Until you deactivate https: then it will renew successfully
    I hope these bugs will be fixed in order to get an automatic renewal
    1
    Matt Kennedy
    This is an absolutely disastrous bug. Why isn't it top priority?
    2
    Ivan Postnikov
    Hello Matt Kennedy
    This ticket has quite high priority internally and it will be fixed. Stay tuned for Plesk change logs updates.
