Extract files from archive using drop-down icon does not replace already existing files in Plesk 12.0
Created:
2016-11-16 13:00:27 UTC
Modified:
2017-08-17 15:09:15 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
  • Plesk 12.0 for Linux
Note: This article has the reference to the issue with the fix available:
  • #PPPM-4253 "When extracting files from an archive using the File Manager, existing files could not be overwritten."
    Fixed in:
Extracting files from archive using a drop-down icon does not replace already existing ones:
alttext
As a result, files with the same name are not replaced with ones from the archive. Old version of the files are kept.
Internal issue with ID #PPPM-4253 , which was fixed in Plesk 12 MU#86 and Plesk 12.5 MU#38 .
Apply latest Plesk microupdates .
