PHP in FastCGI mode does not work. It seems to work properly with SELinux disabled, but it generates error when it is in "Enforcing" state.
# getenforce
Enforcing
Apache error log files contain the following entries
In domains error log /var/www/vhosts/example.com/logs/error_log:
PLESK_INFO: [warn] [client 203.0.113.2] (104)Connection reset by peer: mod_fcgid: error reading data from FastCGI server
[error] [client 203.0.113.2] Premature end of script headers: info.php
In server wide error log /var/log/httpd/error_log:
PLESK_INFO: failed to open log file /var/log/httpd/suexec_log
fopen: Permission denied
In
log file can be found the following error:
PLESK_INFO: [2017-08-07 23:58:46]: uid: (10004/johndoe) gid: (503/503) cmd: cgi_wrapper [2017-08-07 23:58:46]: failed to setgid (503: cgi_wrapper)
Invalid SELinux security context.
Connect to the server using SSH.
Set the correct security context to the
/usr/sbin/suexec
binary# chcon system_u:object_r:httpd_suexec_exec_t:s0 /usr/sbin/suexec
Note: To make this change persistent:
# yum -y install policycoreutils-python
# semanage fcontext -a -t httpd_suexec_exec_t /usr/sbin/suexec
# restorecon -Rvv /usr/sbin/suexec
