Plesk for Linux
kb: technical
ABT: Group B
- On a Plesk for Linux server, Postfix is used as a mail server.
- SMTPS connection from Outlook to the Plesk server fails to be established.
- The following errors are found in the file
/var/log/maillog
CONFIG_TEXT: SSL_accept error from unknown[203.0.113.2]: lost connection
lost connection after CONNECT from unknown[203.0.113.2]
plesk postfix/smtpd[6814]: warning: SASL authentication failure: realm changed: authentication aborted
plesk postfix/smtpd[6814]: warning: 203.0.113.2.example.com[203.0.113.2]: SASL DIGEST-MD5 authentication failed: authentication failure - Plaintext authorization is disabled in Postfix:
# cat /etc/postfix/main.cf | grep "smtpd_sasl_security_options"
smtpd_sasl_security_options = noplaintext
Outlook is not compatible with CRAM-MD5 authentication mechanism.
- Connect to the server using SSH.
- Open the file
for editing. - Comment out the following line by putting "#" at its beginning and save the changes:
CONFIG_TEXT: #smtpd_sasl_security_options = noplaintext
- Restart postfix to apply configuration changes:
# service postfix restart
4 comments
I get this type of error in logs from other smtp/mail servers that cannot communicate with our Plesk mail server.
I there any handshake problem?
I have grep 'smtpd_tls_mandatory_protocols' /etc/postfix/main.cf
smtpd_tls_mandatory_protocols = TLSv1 TLSv1.1 TLSv1.2
Regards, Miha
Hello @Miha, please, try the solution from this article.
thx, I will try to reinastall ca-certificates. Is plesk repair mail needed?
Regards, Miha
@Miha
Yes, it is required to repair mail server configuration.
