SMTP outgoing connection over TLS does not work in Outlook: lost connection lost connection after CONNECT from unknown
Created:
2016-11-16 12:59:00 UTC
Modified:
2017-08-16 04:22:35 UTC
2
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
SMTP outgoing connection over TLS does not work in Outlook.
The following error can be found in /var/log/maillog :
PLESK_INFO: SSL_accept error from unknown[203.0.113.2]: lost connection
lost connection after CONNECT from unknown[203.0.113.2]
Plaintext authorization is disabled:
# less /etc/postfix/main.cf | grep "smtpd_sasl_security_options"`
smtpd_sasl_security_options = noplaintext
Errors like the following are logged into /var/log/maillog :
PLESK_INFO: mail postfix/smtpd[6814]: warning: SASL authentication failure: realm changed: authentication aborted
mail postfix/smtpd[6814]: warning: 203.0.113.2.example.com[203.0.113.2]: SASL DIGEST-MD5 authentication failed: authentication failure
Outlook is not compatible with CRAM-MD5 authentication mechanism.
Allow plaintext authentication in Postfix:
1. Login to the server over SSH
2. Comment out the folllowing in /etc/postfix/main.cf :
CONFIG_TEXT:  smtpd_sasl_security_options = noplaintext
3. Apply configuration changes:
# /etc/init.d/postfix restart
