Web Presence Builder: links to site pages do not work on a published site: Failed to update Panel
Created:
2016-11-16 12:58:19 UTC
Modified:
2017-08-16 16:04:46 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Windows
I have configured a text link on my site using " A page of this site ":
However the link does not work on the published site. Also the following error is shown in Plesk Panel on page " Home ":
Failed to update Panel. To solve this problem, you can send the update log to Parallels support.
Installation of the latest microupdate completed with an error:
mysql> select startTime, status from psa.longtasks where type='panel-update';
| startTime | status |
| 2013-12-25 14:51:25 | error |
Reinstall the micro-updates:
Plesk 11.x for Windows:
%plesk_bin%\\ai.exe --select-product-id panel --select-release-current --reinstall-patch --install-component base
Where %plesk_bin% is path to directory with Plesk backend utilities (e.g., C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\bin )
Plesk 11.x for Linux:
~# /usr/local/psa/admin/sbin/autoinstaller --select-release-current --reinstall-patch --install-component base
For Debin/Ubuntu :
~# /opt/psa/admin/sbin/autoinstaller --select-release-current --reinstall-patch --install-component base
Additional information
Web Presence Builder: external links do not work on a published site
