When opening Plesk in a web-browser, the following error is shown:
PLESK_INFO: 403 Forbidden
The sw-engine service cannot be started with the following error message:
# service sw-engine start
Starting sw-engine-fpm: WARNING: Nothing matches the include pattern '/etc/sw-engine/pool.d/*.conf' from /etc/sw-engine/sw-engine-fpm.conf at line 6.
ERROR: No pool defined. at least one pool section must be specified in config file
ERROR: failed to post process the configuration
ERROR: FPM initialization failed
[FAILED]
Plesk packages are not installed properly or removed.
Connect to the Plesk server via SSH and run Plesk Installer in a command-line interface to complete the installation.
If no packages are marked for installation (*) or the issue persists after installing them, recreate the Plesk file manually:
Create the
plesk.conf
file:# touch /etc/sw-engine/pool.d/plesk.conf
Open the created file in a text editor. In this example, we are using the vi editor:
CONFIG_TEXT: [plesk]
user = psaadm
group = psaadm
listen = /var/run/sw-engine.sock
listen.owner = sw-cp-server
listen.group = root
listen.mode = 0600
pm = ondemand
pm.start_servers = 0
;pm.min_spare_servers = 2
;pm.max_spare_servers = 8
pm.max_children = 26
pm.process_idle_timeout = 30s
;pm.max_requests = 10
;slowlog = /var/log/sw-cp-server/slow.log
;request_slowlog_timeout = 10s
;catch_workers_output = yes
request_terminate_timeout = 600s
security.limit_extensions = .php .php3
env[PATH] = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
php_value[auto_prepend_file] = auth.php
php_value[error_log] = /var/log/plesk/panel.log -
Save the changes and close the file.
Start the sw-engine service:
