AWStats not working
Created:
2016-11-16 12:57:56 UTC
Modified:
2017-08-16 16:31:21 UTC
Have more questions?
Submit a request
AWStats not working
  • Plesk 10.x for Windows
  • Plesk 11.x for Windows
Statistics does not calculate automatically for domain.
IIS log contains a several thousand of records with a lot of '\\0' symbols. A chunk of IIS log for domain:
2012-11-15 11:31:20 W3SVC31339 DSVR014427 77.68.107.67 GET /images/logos/logo-Garvalin-2009.jpg - 80 - 86.167.86.176 HTTP/1.1 Mozilla/5.0+(Macintosh;+Intel+Mac+OS+X+10_7_4)+AppleWebKit/534.56.5+(KHTML,+like+Gecko)+Version/5.1.6+Safari/534.56.5 - http: [... a lot of \\0 symbols ...] 694 69
2012-11-17 08:58:16 W3SVC31339 DSVR014427 77.68.107.67 GET /images/bg.png - 80 - 86.22.177.208 HTTP/1.1 Mozilla/5.0+(Macintosh;+Intel+Mac+OS+X [... a lot of \\0 symbols ...] 8 W3SVC31339 DSVR014427 77.68.107.67 GET /images/logos/logo-Garvalin-2009.jpg - 80 - 86.173.146.23 HTTP/1.1 Mozilla/5.0+(compatible;+MSIE+9.0;+Windows+NT+6.1;+WOW64;+Trident/5.0) - http://www.doamin.tld/ www.doamin.tld 200 0 0 5139 344 94
2012-11-20 04:12:53 W3SVC31339 DSVR014427 77.68.107.67 GET /robots.txt - 80 - 178.154.243.118 HTTP/1.1 Mozilla/5.0+(compatible;+YandexBot/3.0;++http://doamin.tld/bots) - - www.doamin.tld [... a lot of \\0 symbols ...] .0+(Macintosh;+Intel+Mac+OS+X+10_6_8)+AppleWebKit/534.55.3+(KHTML,+like+Gecko)+Version/5.1.5+Safari/534.55.3 - http://www.doamin.tld/ www.doamin.tld 200 0 0 4141 380 43
The records above contains a lot of '\\0' symbols. You can see it in Notepad with Word Wrap switched. Utility 'statistics.exe' interprets it as the end of file.
Also it isn't good to use huge IIS logs rotation like 200MB.It is recommended about 10MB or daily log rotation.
To fix the issue remove blank records from log and recalculate statistics with command line:
C:\\plesk\\admin\\bin>statistics.exe --process-domains=domain.tld --verbose
Use Notepad with Word Wrap to find these records in IIS log.
