Administrator receives notifications: rerun-parts: /etc/cron.hourly/asl exited with return code 1
Created:
2016-11-16 12:56:50 UTC
Modified:
2017-08-16 17:34:40 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 12.0 for Linux
After aum was updated to 4.0.19-39 version administrator receives following notifications from Cron Daemon:
Error: ASL has not been configured
Also, the error may be:
run-parts: /etc/cron.hourly/asl exited with return code 127
Misconfiguration of updated aum package.
Update the aum package in the system, it should be not less than 4.0.19-40 . You can update it with the following commands:
# apt-get update
# apt-get upgrade
If you do not want to install all the available updates but only aum package, you can use the following command:
# apt-get install --only-upgrade aum
