AWStats statistics not updated for all domains
Created:
2016-11-16 12:56:32 UTC
Modified:
2017-08-16 17:25:20 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 9.x for Linux
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
  • Plesk 10.x for Linux
  1. AWStats statistics are not updated on the plesk-stat/webstat page. The issue exists for ALL domains that use AWStats.
  2. If enable debug output for the statistics utility:
    # export STATISTICS_DEBUG=yes
, and run statistics calculation the following error occurs:
    # /usr/local/psa/admin/bin/statistics --calculate-one --domain-name domain.tld
Main HTML page is 'awstats.example.com-http.html'.  sh: /srv/www/cgi-bin/awstats.pl: No such file or directory  Build main page: "/srv/www/cgi-bin/awstats/awstats.pl" -config=example.com-https -staticlinks -configdir=/usr/local/psa/etc/awstats -month=10 -year=2012 -output  Build errors404 page: "/srv/www/cgi-bin/awstats/awstats.pl" -config=example.com-https -staticlinks -configdir=/usr/local/psa/etc/awstats -month=10 -year=2012 -output=errors404  21 files built.
Most likely AWSTATS_BIN_D value is wrong in /etc/psa/psa.conf configuration file.
Change the AWSTATS_BIN_D value from /srv/www/cgi-bin to /srv/www/cgi-bin/awstats in /etc/psa/psa.conf configuration file.
