How to configure certificate for SMTP, IMAP, and POP3 over SSL on Plesk server?
2 comments
    Nigel
    Do you know how to disable using certificate? While configuring an e-mail client, we have to manually change the Connection Security to NONE from STARTTLS which is detected manually. We cant either configure the account in Outlook.
    Appreciate your help.
    Bulat Tsydenov
    @Nigel, Hi!
    The only way is to disable secure connections in mail server configuration.
