Maillog is not updated
Created:
2016-11-16 12:55:15 UTC
Modified:
2017-08-16 16:59:32 UTC
1
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk Onyx for Linux
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
  1. Mail log file /usr/local/psa/log/maillog is empty and/or does not get updated when mail is sent/received on the server.
  2. POP/IMAP statistics are shown empty or incorrect on any domain in Parallels Plesk Panel.
File descriptors for maillog are not added to syslogd.pid
# ps aux | grep syslog
root 2524 0.0 0.0 105372 1320 ? Sl 00:46 0:00 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
root 2878 1.0 0.0 103248 840 pts/3 S+ 00:47 0:00 grep syslog
# ls -l /proc/2524/fd
total 0
lr-x------ 1 root root 64 Oct 12 00:48 0 -> /proc/kmsg
l-wx------ 1 root root 64 Oct 12 00:48 1 -> /var/log/messages
lrwx------ 1 root root 64 Oct 12 00:48 2 -> socket:[10483787]
  1. Check configuration file /etc/rsyslog.conf . Following string should not be commented. If they are commented, correct it:
    #$ModLoad imuxsock # provides support for local system logging (e.g. via logger command)
  2. Make sure that maillog is specified as follows:
    mail.*                                          -/usr/local/psa/var/log/maillog
  3. Restart the service .
    # /etc/init.d/rsyslog restart
For RHEL 7 there is a bug 1088021 .
Workaround
Remove /var/lib/rsyslog/imjournal.state and restart rsyslog service:
    # rm /var/lib/rsyslog/imjournal.state
# systemctl restart rsyslog.service
If it doesn't help comment $OmitLocalLogging on in /etc/rsyslog.conf and restart rsyslog service
    ~]# cat /etc/rsyslog.conf | grep OmitLocalLogging
#$OmitLocalLogging on
