What ColdFusion versions are supported by Plesk?
    Nucleus Inc. NOC
    it says in the change log that CF is no longer supported in plesk 12.5
    I get that it wont work with NEW plesk installs but If i have it installed already in Plesk 12.0, and upgrade to 17.5 or 17.8 will all the CF functions still work? or have they been removed from plesk completely.
    Alexandr Tumanov
    Hello, Plesk will not be able to manage this component after an upgrade.
    And it should not be removed.
