Is it possible to create and use wildcard SSL certificates in Plesk?
2 comments
    sia rez
    Do I have to add the same wildcard SSL/TLS Certificate for each subdomains I create individually?
    Bulat Tsydenov
    @sia rez, Hi!
    If you create subdomains within the same subscriptions, then there is no need to add wildcard certificate for each subdomain. When you create one certificate, it is available for each domain and subdomain in subscription.
