How to create and use wildcard SSL certificates in Plesk?
8 comments
    sia rez
    Do I have to add the same wildcard SSL/TLS Certificate for each subdomains I create individually?
    Bulat Tsydenov
    @sia rez, Hi!
    If you create subdomains within the same subscriptions, then there is no need to add wildcard certificate for each subdomain. When you create one certificate, it is available for each domain and subdomain in subscription.
    Miha Gregorš
    is it possible to create and use wildcard Let's encripty AutoSSL certificates for wildcard subdomain names (like *.example.com)?
    Regards, Miha
    Ivan Postnikov
    Hello @Miha,
    According to this article, it is not yet implemented.
    1
    Miha Gregorš
    thx a lot!
    Regards, Miha
    Tobias Buschor
    If i use "Quick Preview on a domain name" it should deliver the certificate of that domain for all previews.
    With this I could also deliver the previews safely.
    Can you adapt this in a later version or is there a simple workaround?
    Lev Iurev
    @Tobias Buschor there is no workaround, because preview using server IP in order to display the website. You could submit feature reuest here:
    https://plesk.uservoice.com/
    Tobias Buschor
    If this is read by someone who would also like to use wildcard-certificates for website-previews, you can vote here:
    https://plesk.uservoice.com/forums/184549-feature-suggestions/suggestions/38180203-to-make-website-preview-on-the-domain-name-in-ples
