- Plesk
Is it possible to create and use wildcard SSL certificates in Plesk?
How to configure Plesk to automatically assign a domain wildcard certificate for new subdomains?
Plesk allows to create and use certificates for wildcard domain names (like *.example.com). Wildcard certificate can be created the same way as usual certificate is generated. The only difference is that the name with "*" sign in the left path. For example, "*.example.com", will match all this domain's subdomains, like mail.example.com, ftp.example.com, etc.
When a subdomain is created within the same subscription, then there is no need to manually add wildcard certificate to the subdomain. The wildcard certificate of main domain is automatically assigned to the newly created subdomain.
Instructions to get a free wildcard are available here:
Getting Free Wildcard SSL/TLS Certificates from Let's Encrypt
Additional information
Is it possible to use Let's Encrypt for wildcard certificates?
5 comments
Do I have to add the same wildcard SSL/TLS Certificate for each subdomains I create individually?
@sia rez, Hi!
If you create subdomains within the same subscriptions, then there is no need to add wildcard certificate for each subdomain. When you create one certificate, it is available for each domain and subdomain in subscription.
is it possible to create and use wildcard Let's encripty AutoSSL certificates for wildcard subdomain names (like *.example.com)?
Regards, Miha
Hello @Miha,
According to this article, it is not yet implemented.
thx a lot!
Regards, Miha
