Process sw-engine produce high CPU usage
Created:
2016-11-16 12:52:56 UTC
Modified:
2017-08-16 16:13:16 UTC
1
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk Onyx for Linux
  • Plesk 11.x for Linux
The sw-engine process on the Plesk server for Linux causes high cpu load:
# ps -o %cpu,%mem,cmd -C sw-engine
%CPU %MEM CMD
0.0 0.5 /usr/bin/sw-engine -c /opt/psa/admin/conf/php.ini -c /opt/psa/admin/conf/php.ini -dauto_prepend_file=sdk.php /opt/psa/admin/plib/modules/plesk-mobile/scripts/push_worker.php
Product bug which has been fixed in the latest version of Plesk Mobile Extension.
  1. Go to Extensions > Extensions Catalog > Plesk Mobile Center 1.7 > Upgrade
  2. If there is already an existing the process of push_worker with high CPU usage, kill the process:
    # pkill push_worker
2 Comments
  • 0
    Avatar
    Peter Debik
    A customer had reported that his version is 1.7, but in the download area there is 1.4 only. Is 1.4 the latest that is available? Is this help article still up-to-date?
  • 0
    Avatar
    Artyom Baranov
    Hi Peter,
    The article has been created for earlier versions of Plesk Mobile Extension.
    I have edited it according to the present moment.
    I could not reproduce the issue with the latest Plesk Mobile 1.7. I can suggest re-installing the extension via Extensions Catalog.
    Should you have any difficulties, please let us know.
