- Plesk 10.x for Linux
- Plesk 11.x for Linux
- Plesk 12.0 for Linux
Apache web configuration files are not generated, and the below error occurs on Plesk Home page:
New configuration files for the Apache web server were not created due to the errors in configuration templates: cat: write error: No space left on device Error writing to /etc/httpd/conf/plesk.conf.d/webmails/roundcube/domain.com_webmail.conf.8CK2J8 . Detailed error descriptions were sent to you by email. Please resolve the issues and click here to generate broken configuration files once again or here to generate all configuration files.
Disk space check shows that
root
partition is fully used:
# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg_datashare-lv_root 9.7G 9.6G 0 100% /
tmpfs 3.9G 92K 3.9G 1% /dev/shm
/dev/sda1 485M 63M 397M 14% /boot
/dev/mapper/vg_datashare-lv_tmp 985M 19M 917M 2% /tmp
/dev/mapper/vg_datashare-lv_var 37G 25G 9.8G 72% /var
The issue caused by insufficient disk space on a mounted partition.
Increase or free up disk space on the corresponding partition.
Rebuild web configuration files with the following command:
# /usr/local/psa/admin/bin/httpdmng --reconfigure-all
