Unable to list APS applications: Search results could not be loaded at the moment
2 comments
    adrianTNT
    On plesk 17.0.17 I am trying to upgrade to 17.5.3 and I am getting:
    Plesk pre-upgrade check
    WARNING: Unable to find "main" IP address in psa database. Please, check http://kb.plesk.com/en/112417 for more details.
    I ran:
    # /usr/local/psa/bin/ipmanage --reread
    No change.
    So for me this is just another inaccurate article.
    I edited in "Server: localhost:3306 »Database: psa »Table: IP_Addresses" and set the "main" field to true for main ip.
    Now it works.
    BTW, in another table (phpmyadmin > psa database > ip_pool) I see the IPs having same "1" id field, looks like a bug to me, maybe someone used bad table schema when defining the ip_pool table ?! If so, nobody cares I guess.
    Konstantin Annikov (Edited )
    adrianTNT,
    Thank you for your input. We have modified the article for the cases when reread does not fix the inconsistency (that case is not typical one. I have tested that in our environment and reread changes 'main' field to true automatically)
    As for ip_pool table, several same ids are being added by design. Let me explain that:
    ip_pool.id value is connected with clients.ip_pool column. So, every customer has one IP pool assigned. And if a customer has several IP addresses, the same amount of entries with common id will be displayed in ip_pool table.
