Plesk upgrade failed: Unknown column ipAddress in where clause
Created:
2016-11-16 12:52:17 UTC
Modified:
2017-08-08 13:42:10 UTC
Have more questions?
Submit a request
  • Plesk for Linux
Plesk Panel upgrade fails with the error message like this:
  • The issue can be caused by the custom directive 'sql-mode' in the '/etc/my.cnf' configuration file.
  • Absence of psa.ServiceNodes.ipAddress field
  1. Remove the custom entry from MySQL configuration.
  2. Restore the 'psa' and 'apsc' databases from pre-upgrade dumps:
        # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -u admin psa < mysql.<previous_plesk_version>-<upgrade_plesk_version>.<date_timestamp.dump
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -u admin apsc < mysql.preupgrade.apsc.<previous_plesk_version>-<upgrade_plesk_version>.<date_timestamp>.dump
    As an example:
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -u admin psa < mysql.preupgrade.11.0.9-11.5.30.20140320-224641.dump
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -u admin apsc < mysql.preupgrade.apsc.11.0.9-11.5.30.20140320-224641.dump
    Pre-upgrade dumps could be found in '/var/lib/psa/dumps'
  3. Run the 'bootstrapper' script to restart upgrade process by the following commands:
    Plesk 11.5
    # /usr/local/psa/bootstrapper/pp<plesk_version>-bootstrapper/bootstrapper.sh prep-install
    # /usr/local/psa/bootstrapper/pp11.5.30-bootstrapper/bootstrapper.sh rerun
    Plesk 12:
    # /usr/local/psa/bootstrapper/pp12.0.18-bootstrapper/bootstrapper.sh prep-install
    # /usr/local/psa/bootstrapper/pp12.0.18-bootstrapper/bootstrapper.sh rerun
