How to enforce Web Presence Builder to generate HTTPS links in sitemap?
Created:
2016-11-16 12:49:57 UTC
Modified:
2017-08-22 06:45:21 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 12.0 for Linux
Is it possible to enforce Web Presence Builder (WPB) to generate links like https://example.com in sitemap?
Note: WPB takes URL value from the site_publish_settings table while generating sitemap.xml. If WPB was installed with Plesk, this setting is updated each time a site is opened in the Editor. And, looking into its source code, http:// is hardcoded there to precede the URL, irrespective of the hosting settings:
 protected function _getDomainUrl($siteUuid)
[skiped]
return 'http://' . $hosting->getDomainName() . '/';
It makes sense to do the described below after all the changes are made to the site.
Update website publication settings in database:
  1. Back up ' sitebuilder5 ' database:
    # mysqldump -uadmin -p`cat /etc/psa/.psa.shadow` sitebuilder5 > sitebuilder5.`date +%F_%H:%M`.sql
  2. Log on to the database and get the current site publication settings:
    # plesk db
    > use sitebuilder5;
    > select * from site_publish_settings where url like '%domain%'\\G
    *************************** 1. row ***************************
    host_id: NULL
    uuid: 0cdeb8a8-d9f2-9fca-3304-2d539e9c1bab
    target_url: pp://1f23954f-e9b3-1ff0-ed7a-9ff398386c95
    fallback_ip: NULL
    url: http://example.com/
    is_mysql_used: 0
    mysql_host: NULL
    mysql_port: NULL
    mysql_user: NULL
    mysql_password: NULL
    mysql_database: NULL
    http_user: NULL
    http_password: NULL
    ftp_mode: NULL
    1 row in set (0.00 sec)
  3. Update the site publication settings:
    > update site_publish_settings set url='https://example.com/' where id=1;
    Query OK, 1 row affected (0.00 sec)
    Rows matched: 1 Changed: 1 Warnings: 0
  4. Publish the website to generate a new sitemap.xml
For Plesk Onyx only: regarding the generating HTTPS links in the sitemap.xml file, check the article #115000798613
