Application Vault packages not showing
Created:
2016-11-16 12:49:11 UTC
Modified:
2017-08-16 18:33:48 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 11.x for Linux
  • Plesk 11.x for Windows
Customers on one Plesk hosting server cannot see any of the Application Vault packages when they go to manage their domains.
Property Provide only applications that I select checked, but not selected any application in list
Application may not be available in case:
  1. Access to Application Catalog permission enabled for subscripton in Subsriptions > domain.tld > Customize > Permissions
  2. property Provide only applications that I select cheked, but not selected any application in list Subsriptions > mydomain.com > Customize > Applications
NOTE: The scenario above is applicable for reseller (subscriber)
Clear checkbox Provide only applications that I select for the subscriber.
Resellers > reseller_name > Customize > Applications tab
Clear the same option for the subscription "mydomain.com".
Subscriptions > domain.tld > Customize > Applications tab
