Is it safe to update Plesk server's system packages using an operating system package manager?
6 comments
    Robin Tong
    Visiting this article a while back I'm sure it used to recommend excluding certain packages from the system updater, has this now changed? I have excluded sendmail, bind-chroot and caching-nameserver in my yum.conf.
    Ivan Postnikov
    @Robin Tong
    Hello!
    I have checked the previous revisions of this articles. There were no recommendations regarding specific packages.
    Robin Tong
    Must have been a similar article then Ivan, I'll see of I can find it! Thanks.
    Ivan Postnikov
    @Robin Tong
    Ok, feel free to contact us back.
    Luigi Albanese
    Just to make sure, i have upgrade to Plesk onyx 17.8. Now Plesk is asking me to update system files via Plesk. Is this ok? or is safe to do so via Plesk web? If it is safe, would you recommend it to be automatically installed?
    thanks.
    Ivan Postnikov
    @Luigi
    Hello!
    It is considered to be safe to install such updates automatically using Plesk. Plesk uses same commands as if it is done manually in CLI.
    Please, bear in mind that upgrade of some packages like Apache may cause short websites accessibility interruption.
