How to define which mail transfer agent (MTA) is used in Plesk and how to switch from QMail to Postfix and back
6 comments
    Arnaud (Edited )
    [Plesk Onyx 17.8.11] > Unknown Plesk command-line utility: "mailmng-server"
    Ivan Postnikov
    Hello @Arnaud, such behavior was not reproduced on a test server, the command worked without issues.
    # plesk sbin mailmng-service --stop-service
    # plesk -v
    Product version: Plesk Onyx 17.8.11 Update #8
    Update date: 2018/05/24 18:04
    Build date: 2018/05/17 15:37
    OS version: CentOS 7.4.1708
    What OS do you use and what mail server do you have installed?
    Arnaud
    weird ...
    here are the same commands,
    no clue about the mail server installed (or maybe no mail server installed, I was trying to setup external smtp but realized a mail server might be mandatory for relaying .. ?)
    root@platform:~# plesk sbin mailmng-service --stop-service
    Unknown Plesk command-line utility: "mailmng-service"
    root@platform:~# plesk -v
    Update date: 2018/05/26 06:27
    Build date: 2018/05/17 10:37
    OS version: Debian 8.10
    Revision: c3fb546fb867ac424d65da14d8b023f11ec0d150
    Architecture: 64-bit
    Wrapper version: 1.2
    root@platform:~#
    Ivan Postnikov
    @Arnaud, sorry for late response, have you tried this article to achieve the goal?
    Arnaud
    Hi, perfectly fine now, my postfix was disabled, and so was mailmng at the same time
    thank you
    - Arnaud
    Ivan Postnikov
    Hello, @Arnaud.
    Thank you for the answer.
